Wondering if Anyone's Bought the FAT P&C Set, 96mm Piston/Cylinder Set Selection |
Highland |
Jun 12 2018, 09:19 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I was just wondering if anyone has bought this P&C set from FAT and have an opinion. FAT says the cylinders are not AA, but from their "own supplier".
https://fatperformance-rimco.com/collection...on-cylinder-set Also, is it better to buy the KB pistons and cylinders from the same supplier (e.g. FAT or EWM) than from 2 separate suppliers? |
Mark Henry |
Jun 12 2018, 10:51 AM
Since FAT and Rimco are now the same ownership the cylinder may be bored stock.
KB pistons it doesn't matter who you get them from EMW still gets a cut, as they are the originators/suppliers and have an exclusive contract with KB to produce them. EMW also has the same exclusive rights to the T4 JE pistons. The KB T4 pistons are a modified pin Ford Pinto piston. |
JOEPROPER |
Jun 12 2018, 10:56 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
I bought my 96mm p+c from FAT/RIMCO. Everything went together nicely but have not yet installed or run the engine yet. Hopeful to be able to report back with startup results soon.
porschetub |
Jun 13 2018, 12:36 AM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Since FAT and Rimco are now the same ownership the cylinder may be bored stock. KB pistons it doesn't matter who you get them from EMW still gets a cut, as they are the originators/suppliers and have an exclusive contract with KB to produce them. EMW also has the same exclusive rights to the T4 JE pistons. The KB T4 pistons are a modified pin Ford Pinto piston. Great info Mark makes sense ,IMO its a well priced option for good parts, I still can't decide on what I read about the AA kits ,earlier they had piston ring gap issues and some said the rings weren't that good,so I find it interesting to see some sell still with US made rings and pistons (IMG:style_emoticons/default/confused24.gif) . |
914Sixer |
Jun 13 2018, 07:33 AM
I used AA 96mm Biral (aluminum fins with steel barrel) and KB pistons with Hastings rings.
Lo-Fi Version | Time is now: 18th May 2024 - 02:00 PM |
