Door handle opener, Need a pointer here.... |
jim_hoyland |
Jun 13 2018, 10:38 AM
Get that VIN ? Group: Members Posts: 9,308 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I’m helping SB914 get his passenger door handle to work. The interior pull works fine; the exterior pull will not work unless I push in on the door first.
Took the handle out; it’s ok There’s not a lot of adjustment for the mechanism and i’m Trying to not remove it. Anyone else had this problem ? Attached image(s) |
jim_hoyland |
Jun 13 2018, 10:59 AM
Thanks for those tips: I’ll clean the handle anyway. With the handle out of the door, I have push against the door to get the arm (?) on the mechanism to move and open the door.
Will try loosiening the screws that hold the mech. To the door and see if it helps. |
BENBRO02 |
Jun 13 2018, 11:15 AM
Member Group: Members Posts: 481 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region |
Thanks for those tips: I’ll clean the handle anyway. With the handle out of the door, I have push against the door to get the arm (?) on the mechanism to move and open the door. Will try loosiening the screws that hold the mech. To the door and see if it helps. Please post the solution when you figure it out. I have the same problem. |
Lo-Fi Version | Time is now: 26th May 2024 - 12:23 AM |
