Door handle opener, Need a pointer here.... |
jim_hoyland |
Jun 13 2018, 10:38 AM
Get that VIN ? Group: Members Posts: 9,309 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I’m helping SB914 get his passenger door handle to work. The interior pull works fine; the exterior pull will not work unless I push in on the door first.
Took the handle out; it’s ok There’s not a lot of adjustment for the mechanism and i’m Trying to not remove it. Anyone else had this problem ? Attached image(s) |
jdamiano |
Jun 13 2018, 10:56 AM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
Your door looks like it needs to be adjusted. Sounds like the latch isn’t lining up and it is binding.
SirAndy |
Jun 13 2018, 11:26 AM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Your door looks like it needs to be adjusted. Sounds like the latch isn’t lining up and it is binding. (IMG:style_emoticons/default/agree.gif) Sounds like the plate that is on the door jamb needs adjusting. That's the only thing that would explain why you have to push the door in before it opens. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 26th May 2024 - 01:01 PM |
