Door handle opener, Need a pointer here.... |
jim_hoyland |
Jun 13 2018, 10:38 AM
Get that VIN ? Group: Members Posts: 9,308 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I’m helping SB914 get his passenger door handle to work. The interior pull works fine; the exterior pull will not work unless I push in on the door first.
Took the handle out; it’s ok There’s not a lot of adjustment for the mechanism and i’m Trying to not remove it. Anyone else had this problem ? Attached image(s) |
TravisNeff |
Jun 13 2018, 11:31 AM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
The door gap sure looks tight. Also, the door could be moved up a couple of mm to match the rear quarter. That might give you a little bit of wiggle room.
Lo-Fi Version | Time is now: 26th May 2024 - 12:20 AM |
