Door handle opener, Need a pointer here.... |
jim_hoyland |
Jun 13 2018, 10:38 AM
Get that VIN ? Group: Members Posts: 9,309 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I’m helping SB914 get his passenger door handle to work. The interior pull works fine; the exterior pull will not work unless I push in on the door first.
Took the handle out; it’s ok There’s not a lot of adjustment for the mechanism and i’m Trying to not remove it. Anyone else had this problem ? Attached image(s) |
jdamiano |
Jun 13 2018, 10:56 AM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
Your door looks like it needs to be adjusted. Sounds like the latch isn’t lining up and it is binding.
bbrock |
Jun 13 2018, 01:30 PM
Your door looks like it needs to be adjusted. Sounds like the latch isn’t lining up and it is binding. And... (IMG:style_emoticons/default/agree.gif) Looks like the whole door needs to be lifted at the hinges. That alone might cure the binding. |
Lo-Fi Version | Time is now: 26th May 2024 - 01:02 PM |
