Door handle opener, Need a pointer here.... |
jim_hoyland |
Jun 13 2018, 10:38 AM
Get that VIN ? Group: Members Posts: 9,309 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I’m helping SB914 get his passenger door handle to work. The interior pull works fine; the exterior pull will not work unless I push in on the door first.
Took the handle out; it’s ok There’s not a lot of adjustment for the mechanism and i’m Trying to not remove it. Anyone else had this problem ? Attached image(s) |
jim_hoyland |
Jun 13 2018, 01:35 PM
Thanks Tom; Is there a trick to loosening the door hinges so the door can be moved up 1 -2 mm ? Seems like the weight could result in the door moving downward ?
Lo-Fi Version | Time is now: 26th May 2024 - 08:56 AM |
