Door handle opener, Need a pointer here.... |
jim_hoyland |
Jun 13 2018, 10:38 AM
Get that VIN ? Group: Members Posts: 9,308 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I’m helping SB914 get his passenger door handle to work. The interior pull works fine; the exterior pull will not work unless I push in on the door first.
Took the handle out; it’s ok There’s not a lot of adjustment for the mechanism and i’m Trying to not remove it. Anyone else had this problem ? Attached image(s) |
cary |
Jun 13 2018, 07:08 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
The latch portion in the door needs a DEEP clean. I use old school carb dip tank solution in my air powered rattler. Then get PB Blaster into the pivot shaft. Once you get the shaft freed up and lubed it will be better magical.
Lo-Fi Version | Time is now: 25th May 2024 - 11:02 PM |
