Door handle opener, Need a pointer here.... |
jim_hoyland |
Jun 13 2018, 10:38 AM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I’m helping SB914 get his passenger door handle to work. The interior pull works fine; the exterior pull will not work unless I push in on the door first.
Took the handle out; it’s ok There’s not a lot of adjustment for the mechanism and i’m Trying to not remove it. Anyone else had this problem ? Attached image(s) |
Richncherie |
Jan 16 2023, 09:32 PM
Newbie Group: Members Posts: 2 Joined: 2-April 15 From: Spokane, Washington Member No.: 18,586 Region Association: Pacific Northwest |
72 914 cannot unlock the driver side door with key with door closed. Removed panel, cleaned and lubed all internal components. Key easily locks and unlocks door IF the door is open. BUT, if door is closed and locked, the key won't unlock the door. What is the adjustment necessary? I'm thinking need to adjust the door jamb piece???
Thanks! |
Lo-Fi Version | Time is now: 18th May 2024 - 07:16 PM |
