914 rubber alternator boot, I have an early boot, crap |
nditiz1 |
Jun 13 2018, 07:34 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So just after praising the customer service of getting this boot to my house in 2 days of placing the order
Update: I have an early boot setup. Must have been before the switch in 73. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.staticflickr.com-18763-1528940079.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.staticflickr.com-18763-1528940080.2.jpg) |
bdstone914 |
Jun 13 2018, 07:50 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Looks like you have a VW bus alternator that uses a larger boot. Can you measure and post a picture of your alternator backing plate?
nditiz1 |
Jun 13 2018, 08:04 PM
I don't think connecting to the alt is the issue. It doesn't fit in the fan hole nor have an extra rubber ring to hold the wire.
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.staticflickr.com-18763-1528941877.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1528941877.2.jpg) |
Matty900 |
Jun 13 2018, 08:11 PM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
Early is larger than the late on those. I found that out on my car too. My 72 also had a spring retainer that the superseded part did not have. I believe that this is one of the parts that Porsche was trying to save money on when the emissions and safety expenditures were cutting into their bottom line.
Attached thumbnail(s) |
nditiz1 |
Jun 13 2018, 08:19 PM
Crap!
Looks like you all only carry the later style one, noooooooooooooooooo. Sigh, ok well at least we cleared that up. So I have an early style boot. |
Matty900 |
Jun 13 2018, 08:40 PM
Crap! Looks like you all only carry the later style one, noooooooooooooooooo. Sigh, ok well at least we cleared that up. So I have an early style boot. Yes. We will probably make the early version and spring clip at some point but have lots of other projects in front of it currently. You can return it for a refund and I will see if I can find a decent used one but I don't think I can get the retaining spring |
914Sixer |
Jun 13 2018, 09:10 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
No it is not just your boot. I sent mine back to Scott this week. He said he was going to get with Mark. Return it.
porschetub |
Jun 14 2018, 12:39 AM
Dumb question perhaps but will the altenator overheat without this and the backing duct cover?,wonder what folks do with the aftermarket upgrade ones which these parts don't fit ?,I would be interested to know.
Mikey914 |
Jun 14 2018, 08:59 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We make a stock like cover. I would recommend running one. Will the car run without it, yes. Will it overheat, probably not, but when you cool a car with air (think about it like a liquid), would you want a leak?
https://shop.914rubber.com/Alternator-Inspe...m?categoryId=-1 As far as the early boot. If I can get a good example, I can make them. Right not my only good one is in my car. Attached image(s) |
ConeDodger |
Jun 14 2018, 09:46 AM
Apex killer! Group: Members Posts: 23,560 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
We make a stock like cover. I would recommend running one. Will the car run without it, yes. Will it overheat, probably not, but when you cool a car with air (think about it like a liquid), would you want a leak? https://shop.914rubber.com/Alternator-Inspe...m?categoryId=-1 As far as the early boot. If I can get a good example, I can make them. Right not my only good one is in my car. I am not sure what I have Mark, but it’s new and you can have it if you need it for reverse engineering. |
ConeDodger |
Jun 15 2018, 04:06 PM
We make a stock like cover. I would recommend running one. Will the car run without it, yes. Will it overheat, probably not, but when you cool a car with air (think about it like a liquid), would you want a leak? https://shop.914rubber.com/Alternator-Inspe...m?categoryId=-1 As far as the early boot. If I can get a good example, I can make them. Right not my only good one is in my car. I am not sure what I have Mark, but it’s new and you can have it if you need it for reverse engineering. Here's a couple pics. I may have two. Attached image(s) |
ConeDodger |
Jun 16 2018, 01:12 PM
Part numbers for the pictured NOS alternator cooling boot:
021903655D WJD2778 2 Someone might be able to check the parts catalog and see if this is early of late. |
bdstone914 |
Jun 16 2018, 02:34 PM
Early is larger than the late on those. I found that out on my car too. My 72 also had a spring retainer that the superseded part did not have. I believe that this is one of the parts that Porsche was trying to save money on when the emissions and safety expenditures were cutting into their bottom line. You are correct. Early and late. I have never pulled a large one from a 914. Mostly have had late engines. Attached thumbnail(s) |
bdstone914 |
Jun 16 2018, 02:39 PM
Crap! Looks like you all only carry the later style one, noooooooooooooooooo. Sigh, ok well at least we cleared that up. So I have an early style boot. Available as a VW Bus boot. Here is one supplier. Attached thumbnail(s) |
ConeDodger |
Jun 16 2018, 03:13 PM
So D is late, B is early?
bdstone914 |
Jun 16 2018, 09:01 PM
914Sixer |
Jun 16 2018, 09:08 PM
To the best of my knowledge is only one version for the 914. The VW bus had 2 versions. Early version is the same as the 914 one with D shape vent. The 75 amp version has a ROUND hole.
Mikey914 |
Jun 16 2018, 11:26 PM
Ive seen both versions. Unfortunately after I made the late.
The early has an extra relief for a large spring clip. |
Lo-Fi Version | Time is now: 26th April 2024 - 06:13 AM |
