914 rubber alternator boot, I have an early boot, crap |
nditiz1 |
Jun 13 2018, 07:34 PM
Senior Member Group: Members Posts: 1,180 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So just after praising the customer service of getting this boot to my house in 2 days of placing the order
Update: I have an early boot setup. Must have been before the switch in 73. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.staticflickr.com-18763-1528940079.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.staticflickr.com-18763-1528940080.2.jpg) |
Mikey914 |
Jun 14 2018, 08:59 AM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We make a stock like cover. I would recommend running one. Will the car run without it, yes. Will it overheat, probably not, but when you cool a car with air (think about it like a liquid), would you want a leak?
https://shop.914rubber.com/Alternator-Inspe...m?categoryId=-1 As far as the early boot. If I can get a good example, I can make them. Right not my only good one is in my car. Attached image(s) |
ConeDodger |
Jun 14 2018, 09:46 AM
Apex killer! Group: Members Posts: 23,574 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
We make a stock like cover. I would recommend running one. Will the car run without it, yes. Will it overheat, probably not, but when you cool a car with air (think about it like a liquid), would you want a leak? https://shop.914rubber.com/Alternator-Inspe...m?categoryId=-1 As far as the early boot. If I can get a good example, I can make them. Right not my only good one is in my car. I am not sure what I have Mark, but it’s new and you can have it if you need it for reverse engineering. |
ConeDodger |
Jun 15 2018, 04:06 PM
We make a stock like cover. I would recommend running one. Will the car run without it, yes. Will it overheat, probably not, but when you cool a car with air (think about it like a liquid), would you want a leak? https://shop.914rubber.com/Alternator-Inspe...m?categoryId=-1 As far as the early boot. If I can get a good example, I can make them. Right not my only good one is in my car. I am not sure what I have Mark, but it’s new and you can have it if you need it for reverse engineering. Here's a couple pics. I may have two. Attached image(s) |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:23 AM |
