Need advice- tips and tricks?, Removal of front lower arms for bushing replacement |
ottox914 |
Jun 15 2018, 07:50 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
What it says. Front bushings are gone. Have a kit to replace them. Need to remove arms to do this. Do I need to remove the strut housing or can I disconnect the ball joint easily enough?
toolguy |
Jun 15 2018, 08:08 AM
Senior Member Group: Members Posts: 1,267 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
disconnect at ball joint. . either the spanner nut or the strut clamp will do. .
Spanner nut needs a fork socket or you beat the nut to death with a punch and chisel and may end up needing a new one. . Pinch / wedge bolt is easy to remove but somewhat difficult to pull the ball joint shaft out from rust and other crud. . You can 'tap' a wedge into the strut clamp slot to help relieve clamping pressure but a pickle fork works best [ but most often tears the rubber ball seal] I was able to find a replacement rubber on EBay from Bulgeria but took 6 weeks to arrive. From my experience, I'd go for the spanner nut. . if you tear the ball joint seal, you'll need to replace the cover at minimum or the entire ball joint. . |
Lo-Fi Version | Time is now: 14th May 2024 - 04:54 AM |
