914-4 1975 Rear Rotor Screw Stripped |
briantrex |
Jun 16 2018, 03:34 PM
Newbie Group: Members Posts: 10 Joined: 18-May 18 From: Brookings, SD Member No.: 22,135 Region Association: Upper MidWest |
I am in the process of restoring my rear brakes. New calipers, new rotors. The rotors and calipers are shot and new ones are on the way. I'm trying to get the old rotors off and I've discovered a rotor attachment screw (one of two) on each rotor is stripped.
One of these on each rotor and the inside pad adjustment screw is stripped on both calipers. Since I am ditching the rotors, can I just bore out the head of the screw, take the rotor off and then either wrench the screw out by the exposed shaft of the screw or, if all else fails, tap it out? I'm probably forgetting something but it seems like a plan... Advice? B T Rex |
TheCabinetmaker |
Jun 16 2018, 03:42 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Drill the head off the screw to remove rotor, then remove the screw with some vice grips, if they don't just screw out by hand.
mepstein |
Jun 16 2018, 03:45 PM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I am in the process of restoring my rear brakes. New calipers, new rotors. The rotors and calipers are shot and new ones are on the way. I'm trying to get the old rotors off and I've discovered a rotor attachment screw (one of two) on each rotor is stripped. One of these on each rotor and the inside pad adjustment screw is stripped on both calipers. Since I am ditching the rotors, can I just bore out the head of the screw, take the rotor off and then either wrench the screw out by the exposed shaft of the screw or, if all else fails, tap it out? I'm probably forgetting something but it seems like a plan... Advice? B T Rex Yes, that method works fine but before you try to remove from the hub, heat the remains of the screw, red hot and while it's cooling, touch an old wax candle or use some penetrating oil. the heat will help to break the bond and the oil or wax will help it unscrew. |
briantrex |
Jun 16 2018, 07:52 PM
Thanks Guys! I went right after them and got them in short order. Now I have to replace them. They seem like they're brass?
mepstein |
Jun 16 2018, 07:58 PM
I did not think it matters much. They just hold the rotor in place. Some anti seize might make it easier next time around.
Dave_Darling |
Jun 16 2018, 07:59 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The screws only hold the rotors to the hubs until the wheels are bolted on, then the bolts do all of the work and the screws are useless... Rumor has it that they were primarily there to keep the rotors from falling off on the assembly line.
--DD |
rgalla9146 |
Jun 17 2018, 05:16 AM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Originals are not brass. |
Lo-Fi Version | Time is now: 29th April 2024 - 01:59 AM |
