Oilpressure noise warning? |
falcor75 |
Jun 17 2018, 12:56 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
As I experienced a blown hose to my front oil cooler yesterday I'm now quite aware that just the little green oil pressure light isnt enough. I would like to add an audio warning aswell.
Has anyone done this? What parts did you use and how did you connect it? |
Maltese Falcon |
Jun 17 2018, 12:46 PM
Advanced Member Group: Members Posts: 4,663 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
If you can check out the circuit board in the gauge cluster of any year Water -cooled Vanagon, there is a small (low o-p) buzzer (located up at the top R corner on the p/c board. It has about 4 solder/ prongs that are easy to heat + seperate. Or just purchase the buzzer at the VW dealer. It actuates below approx 15 psi...signal sent off of a VW Vanagon (low) op sender (standard 1/8" npt).
I found this out when putting 911 engines (dry sump) into Vanagons (wet sump)...and the low op when the 911 engine is idling would start the Buzzer going (IMG:style_emoticons/default/thumb3d.gif) Marty |
Lo-Fi Version | Time is now: 22nd May 2024 - 05:07 AM |
