Oilpressure noise warning? |
falcor75 |
Jun 17 2018, 12:56 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
As I experienced a blown hose to my front oil cooler yesterday I'm now quite aware that just the little green oil pressure light isnt enough. I would like to add an audio warning aswell.
Has anyone done this? What parts did you use and how did you connect it? |
falcor75 |
Jun 17 2018, 12:50 PM
I found a kit for a timing module that is adjustable between one second and 60 hours. I might go pick one up and experiment a little with it.
https://www.velleman.eu/downloads/0/minikit...anual_mk188.pdf I'm thinking I would use the "start with pause" for the earth side of the buzzer, then when the earth is enabled the light has gone out and the buzzer only triggers if the light comes on before the ignition is turned off. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:40 PM |
