Headlights don't pop up!, Headlights not working - relay? |
Moose01 |
Jun 18 2018, 08:53 AM
Newbie Group: Members Posts: 15 Joined: 14-November 10 From: Houston, Tx Member No.: 12,386 Region Association: None |
Guys,
My headlights are not working, i.e they are not popping up. I have fogs. Would it be the relay? Any ideas before I start pulling relays etc. The fuses are all good! Chris |
Dave_Darling |
Jun 18 2018, 09:30 PM
There is one relay on each headlight motor. So chances are that both staying down is not a relay issue. You can try to verify by swapping the headlight motor relays (they're right next to the headlights) with some of the relays on the relay board in the engine bay.
It's much more likely to be something in the wiring or the switch. Most other things would only affect a single light. --DD |
Lo-Fi Version | Time is now: 16th May 2024 - 11:01 PM |
