Headlights don't pop up!, Headlights not working - relay? |
Moose01 |
Jun 18 2018, 08:53 AM
Newbie Group: Members Posts: 15 Joined: 14-November 10 From: Houston, Tx Member No.: 12,386 Region Association: None |
Guys,
My headlights are not working, i.e they are not popping up. I have fogs. Would it be the relay? Any ideas before I start pulling relays etc. The fuses are all good! Chris |
marksteinhilber |
Jun 20 2018, 01:44 PM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
internal switch cleaning described above may do the trick! I had a problem where one of the headlights would not go up and down without giving it a little help spinning the knob on the motor. I removed the motor to the workbench and opened up the gearbox that the wires go into. There are contacts inside there for limit switches. I found old grease and weak spring tension on some contacts. I cleaned and regreased the contacts and that restored proper function.
Lo-Fi Version | Time is now: 16th May 2024 - 10:04 PM |
