Shift rod for /6, Can I make one from my /4? |
PanelBilly |
Jun 20 2018, 11:32 AM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I have a /4 shift rod that matches a sleeve in the transmission housing very nicely. I’m wondering if I can cut both ends off and weld on a straight pipe
rgalla9146 |
Jun 20 2018, 07:55 PM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I have a /4 shift rod that matches a sleeve in the transmission housing very nicely. I’m wondering if I can cut both ends off and weld on a straight pipe Here you go. Side shift ends, rear shift center section. I cut and rotated the center section to create offset. Also, take Daves advise and do the job using a jig. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 07:42 PM |
