Shift rod for /6, Can I make one from my /4? |
PanelBilly |
Jun 20 2018, 11:32 AM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I have a /4 shift rod that matches a sleeve in the transmission housing very nicely. I’m wondering if I can cut both ends off and weld on a straight pipe
Dave_Darling |
Jun 20 2018, 01:09 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Build a jig first, so that the ends are held in precise alignment. That will save you a lot of headache...
--DD |
worn |
Jun 20 2018, 10:21 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Build a jig first, so that the ends are held in precise alignment. That will save you a lot of headache... --DD (IMG:style_emoticons/default/agree.gif) I cut pie s ections out at each. End to allow m e to bend the rod more. Easily. After determining that it worked I welded in the slots. |
Lo-Fi Version | Time is now: 19th May 2024 - 07:57 PM |
