SOLD 1975 2.0 backdated, exceptional condition. $22,500 |
914ltd |
Jun 20 2018, 05:05 PM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
SOLD I have an exceptionally nice 1975 914 2.0 available. Forest (Zambezi) Green, black original interior. S/N 4752902519. Thia car has a 1973 914 2.0 engine #GA003665, European spec, 100 DIN HP replacing the stock 84 HP 1975 engine. This engine is completely and properly rebuilt using Mahle European pistons and cylinders, new bearings on a std/std crankshaft, new stock grind camshaft. rebuilt heads with new exhaust valves, valve seats and valve guides. The engine retains the original fuel injection. New Bolsby FI harness. Runs excellent, no leaks. Also installed are the less restrictive 1973 2.0 heat exchangers and a new Bursch muffler. This car was completely disassembled for a high quality repaint of the original color, Forest Green, L 64 K, 10 years ago and still doesn't show any bubbles, rust, dents or flaws. There is no over spray from the repaint. The interior is stock and only has 2 small cracks in the dash top corner, not visible to the driver. This 914 was purchased 21 years ago from California and has not seen any Midwest winters. The chassis is as exceptional as the rest of the car with absolutely no rust in the floors, longitudinals, suspension, sail panels or door jams. No crashes, excellent panel gaps, rare original windshield. The brake calipers have been rebuilt, new brake hoses and master cylinder. All original features perform as new, even the windshield washer works. Options include fog lights, Fuchs alloy wheels, center console with working gauges, even the original clock keeps time! "Everything works"
This car idles, runs, drives, accelerates, upshifts, downshifts and stops the way it did 43 years ago except even better. $22,500. Brad Mayeur Attached image(s) |
orthobiz |
Aug 3 2018, 07:17 AM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
This beauty must be gone by now...great car. Too bad I have four already!
Paul l |
Lo-Fi Version | Time is now: 6th May 2024 - 10:25 AM |
