Cutting front of rear of trunk to make room for distributor, Chevy V8 Conversion |
DickSteinkamp |
Jun 20 2018, 05:35 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
I'm currently running a Mallory dual point distributor, mechanical advance only, with a crab cap in my SBC powered 914. Renegade kit. With this set up, the dizzy fits neatly under the front of the rear trunk overhang with no cutting required. I can even R & R the dizzy if I temporarily lower the engine an inch or so.
I'm not crazy about the lack of vacuum advance, however. Any dizzy with vacuum advance (that I have seen or tried) will require I cut a notch out of the front of the rear trunk. If I do that, I'd like to fabricate a little removable "dog house" to cover the cut out to seal up the rear trunk again. The problem seems to be that if the dog house is tall enough to clear a generic points type Chevy dizzy (for example), it may be too tall to stow the roof panel. I'm sure this has been done many times before. What's the solution? Thanks. |
76-914 |
Jun 21 2018, 11:19 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
DickSteinkamp |
Jun 21 2018, 12:17 PM
Thanks! Great pictures. That's what I had envisioned. Even a stock points type dizzy. It still "looks" to me like the roof panel will not fit in the trunk with this set up due to the height of the "dog house". I hope I'm wrong. If not, can the dog house be made any shorter and still clear the dizzy? |
76-914 |
Jun 21 2018, 05:45 PM
Thanks! Great pictures. That's what I had envisioned. Even a stock points type dizzy. It still "looks" to me like the roof panel will not fit in the trunk with this set up due to the height of the "dog house". I hope I'm wrong. If not, can the dog house be made any shorter and still clear the dizzy? It is close but the lid still fits in there! (IMG:style_emoticons/default/beerchug.gif) |
DickSteinkamp |
Jun 21 2018, 05:47 PM
Great! Thanks for your help. |
Lo-Fi Version | Time is now: 25th May 2024 - 07:12 AM |
