Cutting front of rear of trunk to make room for distributor, Chevy V8 Conversion |
DickSteinkamp |
Jun 20 2018, 05:35 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
I'm currently running a Mallory dual point distributor, mechanical advance only, with a crab cap in my SBC powered 914. Renegade kit. With this set up, the dizzy fits neatly under the front of the rear trunk overhang with no cutting required. I can even R & R the dizzy if I temporarily lower the engine an inch or so.
I'm not crazy about the lack of vacuum advance, however. Any dizzy with vacuum advance (that I have seen or tried) will require I cut a notch out of the front of the rear trunk. If I do that, I'd like to fabricate a little removable "dog house" to cover the cut out to seal up the rear trunk again. The problem seems to be that if the dog house is tall enough to clear a generic points type Chevy dizzy (for example), it may be too tall to stow the roof panel. I'm sure this has been done many times before. What's the solution? Thanks. |
jim_hoyland |
Jun 21 2018, 05:49 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Which tach adapter are you using ?
DickSteinkamp |
Jun 21 2018, 05:56 PM
Which tach adapter are you using ? TachAdapt (IMG:http://www.914world.com/bbs2/uploads_offsite/ashlocktech.com-20876-1529625406.1.png) |
jim_hoyland |
Jun 21 2018, 07:22 PM
Which tach adapter are you using ? TachAdapt (IMG:http://www.914world.com/bbs2/uploads_offsite/ashlocktech.com-20876-1529625406.1.png) I have a question regarding the 6 tiny switches inside the Adapter. Which two did you select and did you remove the “jumper” ? Reason I ask: I helping to set one up on a V8 conversion. So far I tried 1 and 6 ; but no tach readings. |
DickSteinkamp |
Jun 22 2018, 08:47 AM
I have a question regarding the 6 tiny switches inside the Adapter. Which two did you select and did you remove the “jumper” ? Reason I ask: I helping to set one up on a V8 conversion. So far I tried 1 and 6 ; but no tach readings. Here are the complete instructions. Instructions |
Lo-Fi Version | Time is now: 18th May 2024 - 02:00 PM |
