Heater blower, Heater blower |
simonjb |
Jun 20 2018, 07:25 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
I’m having a bit of an issue with getting the heater blower to work...
The motor bench tests fine The wire on the heater control lever is connected correctly When I pull the lever back, I can hear the relay clicking in the engine bay However, when I connect the fan to the heater wire the motor does not run. I confirmed that brown connected to brown and green to yellow, just like the picture below. I was holding the motor - so it wasn’t separately grounded - would that be the issue? Any ideas ? |
Tbrown4x4 |
Jun 21 2018, 04:46 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Maybe the relay contacts are bad?
A clicking relay doesn't mean any current is flowing through the relay. Can you try another? |
rhodyguy |
Jun 21 2018, 07:23 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The tunnel warm air lever may be compromised. The contact 'nub' that powers the fan when the lever is pulled up fully may not be making proper contact. Does the fan spin up to speed when powered independently?
Shredhead |
Jun 21 2018, 07:57 AM
Member Group: Members Posts: 110 Joined: 10-August 15 From: CT Member No.: 19,047 Region Association: North East States |
The tunnel warm air lever may be compromised. The contact 'nub' that powers the fan when the lever is pulled up fully may not be making proper contact. Does the fan spin up to speed when powered independently? If that was the issue, the relay wouldn't click, no? |
GeorgeRud |
Jun 21 2018, 08:13 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Try another relay.
simonjb |
Jun 21 2018, 03:35 PM
No luck with a new relay that I know is good
SirAndy |
Jun 21 2018, 03:37 PM
Resident German Group: Admin Posts: 41,618 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Tbrown4x4 |
Jun 21 2018, 05:01 PM
He said the fan "bench tests fine". I ASS-U-ME he means fan on bench with power and ground applied=fan works.
Brown to fan is ground (from the ground point above the relay board, I believe). Make sure there is a GOOD ground. Green to fan comes from the heater fan relay. It should have battery voltage with the fan relay closed. The control side of the relay (the coil) is grounded by the fan lever switch. I believe this is good because the relay is heard clicking. The 25A fuse on the relay board supplies battery voltage to the relay (input, if you will), and when the relay contacts close, the green wire is energized. If you hear the relay click, and you do not have power at the green wire on the fan, the fuse is bad, the relay board is bad, OR the relay is bad. Do you have battery power at the green wire to the fan? And does the fan have a good ground? BTW, a voltmeter is better than a test light. An old test light can operate on as little as 3V, so the circuit could look OK, but not be able to run whatever load is on it. |
simonjb |
Jun 21 2018, 05:20 PM
You assumed right. But no power at the fan. So I’ll check the fuse and wire. Thanks guys
dr914@autoatlanta.com |
Jun 21 2018, 05:24 PM
914 Guru Group: Members Posts: 7,833 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Steve |
Jun 22 2018, 07:58 AM
914 Guru Group: Members Posts: 5,573 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Pretty simple circuit to troubleshoot. Lever pulled all the way up, connects relay to ground. Should be 12 volts at relay. Using a digital volt meter or analog meter, check for power and ground at the blower.
Lo-Fi Version | Time is now: 5th May 2024 - 01:33 AM |
