Heater blower, Heater blower |
simonjb |
Jun 20 2018, 07:25 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
I’m having a bit of an issue with getting the heater blower to work...
The motor bench tests fine The wire on the heater control lever is connected correctly When I pull the lever back, I can hear the relay clicking in the engine bay However, when I connect the fan to the heater wire the motor does not run. I confirmed that brown connected to brown and green to yellow, just like the picture below. I was holding the motor - so it wasn’t separately grounded - would that be the issue? Any ideas ? |
simonjb |
Jun 21 2018, 05:20 PM
You assumed right. But no power at the fan. So I’ll check the fuse and wire. Thanks guys
dr914@autoatlanta.com |
Jun 21 2018, 05:24 PM
914 Guru Group: Members Posts: 7,872 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Lo-Fi Version | Time is now: 24th May 2024 - 08:04 PM |
