914-6 GT oil cooler set up install and prototyping thread. |
mb911 |
Jun 20 2018, 07:35 PM
914 Guru Group: Members Posts: 6,818 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I have been putting parts together for this for a long time. I started with oil lines (hard gt lines) , oil tank side oil lines, now onto cooler and lines up to it.. Next will be t stat area.
I want to share what progress along the way as folks ask me often if I have a kit and well "working on it" Here is a really nice oil cooler I plan to use in the kit. Notice the angle of the inlets and how they are divided.. |
mb911 |
Jun 20 2018, 07:37 PM
mepstein |
Jun 20 2018, 08:27 PM
914-6 GT in waiting Group: Members Posts: 19,247 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
911’s use 3 clamps but the oil lines are longer. I think 2 clamps would be best since one might allow the lines to pivot at the clamp. It’s easier to hold a long metal pipe steady with two hands instead of one. But I’m just guessing.
Glad to see this is moving forward. |
TravisNeff |
Jun 20 2018, 09:01 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Do the door sill supports need to come out for this, or just opened up a bit?
mb911 |
Jun 21 2018, 05:05 AM
Do the door sill supports need to come out for this, or just opened up a bit? They really need to come out. Was hoping to leave them in and modify but wouldn't work. Regarding clamps the other spot its held is where it enters the cockpit. There is no real movement. And factory was brass these are stainless so it doesn't need as much support. |
GeorgeRud |
Jun 21 2018, 08:19 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Perhaps some type of support could be fabricated to hold the oil lines and also support the door sill?
mb911 |
Jun 21 2018, 10:25 AM
Probably so..
Socalandy |
Jun 22 2018, 11:21 AM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
We used factory 911 brackets.
Attached image(s) |
mb911 |
Jun 22 2018, 11:24 AM
Socalandy |
Jun 22 2018, 11:26 AM
Attached image(s) |
Mueller |
Jun 22 2018, 12:21 PM
Lines look too nice to put the cover back on!
mb911 |
Jun 25 2018, 10:18 AM
mb911 |
Jun 25 2018, 10:19 AM
mb911 |
The front side I put diverters in as well. Not pictured yet..
mb911 |
Jun 26 2018, 10:37 AM
mb911 |
Jun 26 2018, 10:38 AM
Martin Baker |
Oct 9 2018, 10:39 PM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
Here is the inlet I bought from Ben. Fitted, welded in, coated with rocker panel texture and painted body color. FYI, this is a bit of a tight fit in a former FAT bumper car...
MB Attached thumbnail(s) |
Martin Baker |
Oct 10 2018, 12:29 PM
Did you get the lines for the front sorted yet?
MB |
mb911 |
Oct 10 2018, 01:56 PM
Did you get the lines for the front sorted yet? MB (IMG:style_emoticons/default/mad.gif) sport of.. Waiting still on them to show up. |
Martin Baker |
Oct 10 2018, 02:43 PM
Well, I really need them now! Local place was lost when they saw the hard lines..."metric crap" this, "PORSCHE crap" that...Pirtek wants me the put weld on ends on the lines to convert to AN. I get tired of hearing the anti PORSCHE stuff, when they have won a F*** ton of races...I guess those lines have a 37 degree flare, and its 30 mm male with 1.5 mm thread pitch? Is that correct?
MB |
Lo-Fi Version | Time is now: 1st May 2024 - 09:30 AM |
