How to convert a 914 transaxle to cable shift, ISO build thread |
HalfMoon |
Jun 21 2018, 09:34 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
So I've heard of some people changing over their 914 side-shift trans-axle's to cable shift but I've never seen a build thread about that. Does anyone know of one and or a vendor that sells a kit?
cary |
Jun 21 2018, 11:32 PM
Steve |
Jun 22 2018, 07:01 AM
914 Guru Group: Members Posts: 5,571 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I’ve watched this over the last 25 years and the feedback has not been good. Patrick Motorsports used to sell the cable shift for the 915 box and the feedback was it was a bitch to adjust it and get it right. They now specialize in the Wevo solution for the 915. I’ve only seen cable shift builds on this site for transmissions designed for cables, namely Subaru, Boxster and cayman.
Optimusglen |
Jun 22 2018, 07:24 AM
Senior Member Group: Members Posts: 905 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
I had found a page where a guy was creating a cable shift setup for the stock trans, but I think it was a rear shift. And it also looked kinda hacked, not a nice kit or anything. I had started down that path, then decided to just switch to side shift and that has been good enough for me.
porschetub |
Jun 23 2018, 12:02 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I had found a page where a guy was creating a cable shift setup for the stock trans, but I think it was a rear shift. And it also looked kinda hacked, not a nice kit or anything. I had started down that path, then decided to just switch to side shift and that has been good enough for me. I think it would take some clever engineering to get it right,believe there was a kit made some years ago,there was one on the Samba not so long ago but not complete. Good cables are expensive Morse are generally the best,then theres rose joints, linkages and SO many hours to get it right ,then would it be better???. |
ruby914 |
Jun 23 2018, 01:31 AM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
So I've heard of some people changing over their 914 side-shift trans-axle's to cable shift but I've never seen a build thread about that. Does anyone know of one and or a vendor that sells a kit? I did one on my Suby car before I changed over to the Suby trans. It worked well. I don't recall if it was better or worse than the shaft. Attached image(s) |
Mike Bellis |
Jun 23 2018, 05:22 PM
I did one. It was a pain in the ass to get everything working correctly. Not sure if I did a thread on it. It shifted slightly better but not good enough to do it again.
So I switched to a Boxster tranny (IMG:style_emoticons/default/biggrin.gif) |
HalfMoon |
Jun 23 2018, 05:38 PM
I did one. It was a pain in the ass to get everything working correctly. Not sure if I did a thread on it. It shifted slightly better but not good enough to do it again. So I switched to a Boxster tranny (IMG:style_emoticons/default/biggrin.gif) I sense that's the direction I'll be moving. I can only assume if it was a mod (cable shift for the 914 trans) that did wonders, their would be odles of folks doing it. That does not seem to be the case. Do I recall there was an Audi 5-sp transaxle that was essentially the same as the Boxter 5 spd? Or was that a VW transaxle....? |
yellowporky |
Jun 23 2018, 05:48 PM
Member Group: Members Posts: 422 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
the boxster 5 speed is made by audi (012) and it was used in the vw passat
HalfMoon |
Jun 23 2018, 05:52 PM
Mike Bellis |
Jun 23 2018, 06:50 PM
1999-2002 Passat
Chris914n6 |
Jun 23 2018, 06:56 PM
Jackstands are my life. Group: Members Posts: 3,310 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I dabbled a little on a cable shift as my engine swap has a tight clearance with the rod, but the rod with good bushings hasn't been a problem for me.
Lo-Fi Version | Time is now: 4th May 2024 - 03:44 PM |
