Front Fresh Air, Removing; how can water be directed . |
jim_hoyland |
Jun 22 2018, 06:16 PM
Get that VIN ? Group: Members Posts: 9,272 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
After removing the fresh air bower assembly, i’m Curious what has been done to direct the water that comes through the grill.
It looks like the frame that held the fresh air box could support a metal pan with a hose connected to drain the water away Anyone made something like this . |
Rand |
Jun 22 2018, 06:20 PM
After removing the fresh air bower assembly, i’m Curious what has been done to direct the water that comes through the grill. It looks like the frame that held the fresh air box could support a metal pan with a hose connected to drain the water away Anyone made something like this . JoeO (Series9) built a custom tray under with a drain. I remember it from the RS build, but that was many years ago. |
Dave_Darling |
Jun 22 2018, 07:52 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
IIRC, the box has two drains in the front corners. That's how the water is supposed to drain out.
--DD |
jim_hoyland |
Jun 22 2018, 08:27 PM
After removing the fresh air bower assembly, i’m Curious what has been done to direct the water that comes through the grill. It looks like the frame that held the fresh air box could support a metal pan with a hose connected to drain the water away Anyone made something like this . JoeO (Series9) built a custom tray under with a drain. I remember it from the RS build, but that was many years ago. That’s what i’d Like to see....,, |
jim_hoyland |
Jun 22 2018, 08:30 PM
Found it, he posted a pic back in 2005. Said he TIG welded it
Attached image(s) |
PlaysWithCars |
Jun 22 2018, 09:46 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
I removed the motor and fan assembly from mine, because that's the vast majority of the weight, and seal the hole with a thin gauge aluminum plate. Then put the original plastic assembly back in place. Saved a lot of weight, didn't cost hardly anything, and no leaks.
GaroldShaffer |
Jun 22 2018, 10:27 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I removed the motor and fan assembly from mine, because that's the vast majority of the weight, and seal the hole with a thin gauge aluminum plate. Then put the original plastic assembly back in place. Saved a lot of weight, didn't cost hardly anything, and no leaks. (IMG:style_emoticons/default/smilie_pokal.gif) Same plan I have to do to my AX car. |
jim_hoyland |
Jun 23 2018, 05:24 AM
I removed the motor and fan assembly from mine, because that's the vast majority of the weight, and seal the hole with a thin gauge aluminum plate. Then put the original plastic assembly back in place. Saved a lot of weight, didn't cost hardly anything, and no leaks. Good Idea (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 12:28 AM |
