Front Fresh Air, Removing; how can water be directed . |
jim_hoyland |
Jun 22 2018, 06:16 PM
Get that VIN ? Group: Members Posts: 9,306 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
After removing the fresh air bower assembly, i’m Curious what has been done to direct the water that comes through the grill.
It looks like the frame that held the fresh air box could support a metal pan with a hose connected to drain the water away Anyone made something like this . |
PlaysWithCars |
Jun 22 2018, 09:46 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
I removed the motor and fan assembly from mine, because that's the vast majority of the weight, and seal the hole with a thin gauge aluminum plate. Then put the original plastic assembly back in place. Saved a lot of weight, didn't cost hardly anything, and no leaks.
GaroldShaffer |
Jun 22 2018, 10:27 PM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I removed the motor and fan assembly from mine, because that's the vast majority of the weight, and seal the hole with a thin gauge aluminum plate. Then put the original plastic assembly back in place. Saved a lot of weight, didn't cost hardly anything, and no leaks. (IMG:style_emoticons/default/smilie_pokal.gif) Same plan I have to do to my AX car. |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:47 AM |
