19mm master cylinder and bigger calipers?, What combo have you upgraded to? |
Mueller |
Jun 23 2018, 12:34 PM
What combo calipers are being used with the 19mm master cylinder besides stock?
Looking to ditch my rear stock calipers since going to drum style parking brakes. I'm open to upgrade front brakes at same time.... 911 parts? 944 turbo parts? Boxster parts? Wilwood parts? I'm open to ideas. |
worn |
Jun 23 2018, 03:54 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
What combo calipers are being used with the 19mm master cylinder besides stock? Looking to ditch my rear stock calipers since going to drum style parking brakes. I'm open to upgrade front brakes at same time.... 911 parts? 944 turbo parts? Boxster parts? Wilwood parts? I'm open to ideas. I run a 19 mm master, and aluminum 911 s calipers up front and 911sc rear brakes aft. The alu calipers are pricey tho. Still I like the setup very much with the five lug setup. |
jcd914 |
Jun 24 2018, 12:00 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
What combo calipers are being used with the 19mm master cylinder besides stock? Looking to ditch my rear stock calipers since going to drum style parking brakes. I'm open to upgrade front brakes at same time.... 911 parts? 944 turbo parts? Boxster parts? Wilwood parts? I'm open to ideas. I run a 19 mm master, and aluminum 911 s calipers up front and 911sc rear brakes aft. The alu calipers are pricey tho. Still I like the setup very much with the five lug setup. I ran 911T struts and brakes on the front of my old 914 with 19mm master cylinder. I don't know what master cylinder my current 914 has but I have a pair of Alfa Romeo Brembo aluminum front calipers that have 3 inch caliper bolt spacing so they bolt on early 911 strut. They would bolt on to 914 struts but the calipers are made for the thicker vented rotors. I have only run 914 rear calipers but have read that 914 front calipers bolt on the rear. Jim |
Lo-Fi Version | Time is now: 17th May 2024 - 06:34 PM |
