Shifter Stop Plate Springs, Any tips or tricks for reinstalling? |
HarveyH |
Jun 23 2018, 01:02 PM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
Converting back from a short shift to a stock shift lever. Any tips or tricks for reinstalling the Stop Plate Springs (Item #13)?
Thanks, Harvey |
dlee6204 |
Jun 23 2018, 01:40 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I start the pin on one side and make the spring into a c-shape and use a small screw driver from the other side. Straighten the spring out and push pin further as I pull screwdriver out. |
troth |
Jun 23 2018, 01:58 PM
Member Group: Members Posts: 151 Joined: 17-August 16 From: CT/WA Member No.: 20,305 Region Association: None |
(IMG:style_emoticons/default/agree.gif) I start the pin on one side and make the spring into a c-shape and use a small screw driver from the other side. Straighten the spring out and push pin further as I pull screwdriver out. The screw driver on the other side is key. Make sure you put one of the retaining clips on before you start. Lots of curse words if you accidentally push it too far. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:35 AM |
