> fuel pressure test., test while engine is turning or not
Michael N
post Jun 12 2005, 06:33 PM
Certifiable
I am trouble shooting a fuel injection system and need to know when adjusting the fuel pressure @28psi, should I be getting that reading with the starter turning or just with the ignition turned on so the fuel pump turns on.
Thanks,
Michael
ClayPerrine
post Jun 12 2005, 06:50 PM
Just hotwire the fuel pump (jumper the relay) and set the fuel pressure. The pump is electric,so it doesn't matter if the engine is running or not. But it's easier to do without worring about the running engine.
Michael N
post Jun 12 2005, 07:11 PM
Certifiable
Let me start by saying, Yes, I know I am an idiot. When I test with the fuel pump on it will only read max 20 psi on the fuel pressure gauge. I can not adjust the fuel pressure regulator to read any higher. If I test with the starter turning the pressure will jump much higher.
Bleyseng
post Jun 12 2005, 08:00 PM
Aircooled Baby!
I usually check it with the motor running, hooking up the gauge on the pressure side of the fuel lines....
Michael N
post Jun 13 2005, 12:03 AM
Certifiable
Thanks for the replys....I was able to get it set properly. Still not the problem but I'll continue to work on it.
Smellin' gas all day has me lightheaded....MUST TAKE BREAK NOW!
- Lo-Fi Version Time is now: 9th July 2025 - 08:18 AM
