Pre-Drilled Drain Plugs?, Are they available? |
GregAmy |
Jun 26 2018, 09:04 AM
Advanced Member Group: Members Posts: 2,298 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Putting aside discussion on whether they're needed...a historics group I'm running with (VRG) is insisting I run with drilled and safety-wired engine and trans drain plug fasteners. In a cursory search through common vendors I'm not able to locate any.
Is anyone aware of pre-drilled engine drain bolt, plate/screen bolt, and trans plugs before I spend the coin on a drill jig? |
GregAmy |
Jun 26 2018, 09:43 AM
Thanks, Chris!
Yes, it's silly. Even more so that someone told me they're not really worried about drain plugs loosening, it's more a visual confirmation that the competitor had verified that the plugs are tightened... I pointed out the design of the trans plug; the response was (paraphrased), "there's a little bit of the flange hanging out, you can run a drill bit and wire through that." Hey, if a piece of wire makes them happy, I'll put a piece of wire through it. |
Lo-Fi Version | Time is now: 14th May 2024 - 11:07 PM |
