Pre-Drilled Drain Plugs?, Are they available? |
GregAmy |
Jun 26 2018, 09:04 AM
Advanced Member Group: Members Posts: 2,298 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Putting aside discussion on whether they're needed...a historics group I'm running with (VRG) is insisting I run with drilled and safety-wired engine and trans drain plug fasteners. In a cursory search through common vendors I'm not able to locate any.
Is anyone aware of pre-drilled engine drain bolt, plate/screen bolt, and trans plugs before I spend the coin on a drill jig? |
GregAmy |
Jun 26 2018, 09:43 AM
Thanks, Chris!
Yes, it's silly. Even more so that someone told me they're not really worried about drain plugs loosening, it's more a visual confirmation that the competitor had verified that the plugs are tightened... I pointed out the design of the trans plug; the response was (paraphrased), "there's a little bit of the flange hanging out, you can run a drill bit and wire through that." Hey, if a piece of wire makes them happy, I'll put a piece of wire through it. |
Chris914n6 |
Jun 26 2018, 06:39 PM
Jackstands are my life. Group: Members Posts: 3,318 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Yes, it's silly. Even more so that someone told me they're not really worried about drain plugs loosening, it's more a visual confirmation that the competitor had verified that the plugs are tightened... Would a dab of paint suffice then? It's the OEM method for such things. |
GregAmy |
Jun 26 2018, 07:42 PM
Would a dab of paint suffice then? Nope, I asked. In fact, anticipating that may be an option I pointed out that not only did I correctly torque the bolts/plugs, that they should notice that I marked with a Sharpie where each bolt was located, and "promised" I would visually check them after each session. That may have assuaged their fears for last weekend and I was allowed to run, but I was given the ole "fix my next race" requirement. I like the idea of the "outtie" drain plugs on the transaxle. But they're pricey at around $25-35 each. I've got the idea that in the future I'll build up a trans cooler system for the car, so what I may do for now is buy the Patrick Motorsports plugs that convert the holes to -8AN fittings ($25 ea) and loop an AN line between them for now (I have enough -8AN fittings and hoses to do it myself). |
Lo-Fi Version | Time is now: 15th May 2024 - 05:12 AM |
