Pre-Drilled Drain Plugs?, Are they available? |
GregAmy |
Jun 26 2018, 09:04 AM
Advanced Member Group: Members Posts: 2,298 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Putting aside discussion on whether they're needed...a historics group I'm running with (VRG) is insisting I run with drilled and safety-wired engine and trans drain plug fasteners. In a cursory search through common vendors I'm not able to locate any.
Is anyone aware of pre-drilled engine drain bolt, plate/screen bolt, and trans plugs before I spend the coin on a drill jig? |
TheCabinetmaker |
Jun 27 2018, 05:43 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Uh, properly done safety wire will stop a bolt from unscrewing. What do you mean by a loose piece of wire? I was a jet mechanic in the Vietnam war. Every nut, bolt, and screw was safety wired, and everytime i wired one a quality control inspector signed off my work. They never came loose.
Lo-Fi Version | Time is now: 15th May 2024 - 06:36 PM |
