Pre-Drilled Drain Plugs?, Are they available? |
GregAmy |
Jun 26 2018, 09:04 AM
Advanced Member Group: Members Posts: 2,298 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Putting aside discussion on whether they're needed...a historics group I'm running with (VRG) is insisting I run with drilled and safety-wired engine and trans drain plug fasteners. In a cursory search through common vendors I'm not able to locate any.
Is anyone aware of pre-drilled engine drain bolt, plate/screen bolt, and trans plugs before I spend the coin on a drill jig? |
GregAmy |
Jun 28 2018, 07:01 PM
Typically, safety wire won't ensure proper torque on a properly-torqued fastener. But it's a common thing on high-vibrations implementations (FAA required I safety-wired my oil filter, and yet it never-ever vibrated loose...coincidence?)
I've never had a properly-torqued drain plug vibrate loose on any race car I've had in nearly 30 years of racing. But if'n'it'll make 'em happy, I'm ok with breaking out those safety wire pliers that are...well, they're somewhere, I'll find 'em. |
Lo-Fi Version | Time is now: 15th May 2024 - 09:18 AM |
