Pre-Drilled Drain Plugs?, Are they available? |
GregAmy |
Jun 26 2018, 09:04 AM
Advanced Member Group: Members Posts: 2,298 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Putting aside discussion on whether they're needed...a historics group I'm running with (VRG) is insisting I run with drilled and safety-wired engine and trans drain plug fasteners. In a cursory search through common vendors I'm not able to locate any.
Is anyone aware of pre-drilled engine drain bolt, plate/screen bolt, and trans plugs before I spend the coin on a drill jig? |
Krieger |
Jul 15 2018, 12:17 PM
Advanced Member Group: Members Posts: 4,707 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
The idea behind the method of proper safety wiring is that if one of the wired bolts tries to loosen the wire is pulling in a manner that effectively tightens the bolt it is wired to. No slack between bolts is important.
Lo-Fi Version | Time is now: 14th May 2024 - 06:40 PM |
