Pre-Drilled Drain Plugs?, Are they available? |
GregAmy |
Jun 26 2018, 09:04 AM
Advanced Member Group: Members Posts: 2,298 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Putting aside discussion on whether they're needed...a historics group I'm running with (VRG) is insisting I run with drilled and safety-wired engine and trans drain plug fasteners. In a cursory search through common vendors I'm not able to locate any.
Is anyone aware of pre-drilled engine drain bolt, plate/screen bolt, and trans plugs before I spend the coin on a drill jig? |
Krieger |
Jul 15 2018, 12:17 PM
Advanced Member Group: Members Posts: 4,707 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
The idea behind the method of proper safety wiring is that if one of the wired bolts tries to loosen the wire is pulling in a manner that effectively tightens the bolt it is wired to. No slack between bolts is important.
GregAmy |
Jul 15 2018, 07:08 PM
The idea behind the method of proper safety wiring is that if one of the wired bolts tries to loosen the wire is pulling in a manner that effectively tightens the bolt it is wired to. No slack between bolts is important. The idea behind safety-wiring oil and trans drain bolts in VRG historics is to use time and money to create someplace to attach safety wire to so someone can glance underneath, see safety wire, check off a box, and pass you for techical inspection. There, I fixed it! (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 06:18 PM |
