Pre-Drilled Drain Plugs?, Are they available? |
Krieger |
Jul 15 2018, 12:17 PM
Advanced Member Group: Members Posts: 4,702 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
The idea behind the method of proper safety wiring is that if one of the wired bolts tries to loosen the wire is pulling in a manner that effectively tightens the bolt it is wired to. No slack between bolts is important.
GregAmy |
Jul 15 2018, 07:08 PM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
The idea behind the method of proper safety wiring is that if one of the wired bolts tries to loosen the wire is pulling in a manner that effectively tightens the bolt it is wired to. No slack between bolts is important. The idea behind safety-wiring oil and trans drain bolts in VRG historics is to use time and money to create someplace to attach safety wire to so someone can glance underneath, see safety wire, check off a box, and pass you for techical inspection. There, I fixed it! (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 04:51 PM |
