1970 914 project |
1970 914 project |
1970-1914 |
Jun 28 2018, 04:35 PM
Member Group: Members Posts: 97 Joined: 3-June 18 From: Vancouver Member No.: 22,186 Region Association: Canada |
I recently bought this partially restored 1970 914 shell off Craigslist for a pretty decent price. I have been looking for quite a while and there are only so many around in the Vancouver BC area and most are quite rusty if they are not $$$$$. The good news is most of the gross nasty metal work was already completed so in that regard I’m pretty far ahead for a project. Also came with quite a few decent parts - some I will use and some I will sell off to get the parts I actually need.
Not sure what I will do about engine choice.... would really like to do a 6 but based on cost I may end up doing a v8 or Subaru? Not sure but luckily I have a ton of other work to do on the rest of the car while I make up my mind. EDIT: V8 it is - Purchased most of a Renegade SBC kit (IMG:style_emoticons/default/smile.gif) The Formula Vee wheels were just way too skinny for the flares so they have been sold and I picked up a set of chrome 15x6 and 15 x7 cookie cutters. Not sure if they will be wide enough either to look correct but the deal was great and they will at least allow me to do the 5 bolt conversion. I have one side of the rear suspension all apart and the rear axle stub out - looks like it is the early style with the raised bosses in place for 5 lug. I will update with some pics once that is done and the trailing arm is back together. |
SirAndy |
Jun 28 2018, 05:14 PM
Resident German Group: Admin Posts: 41,609 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I picked up a set of chrome 15x6 and 15 x7 cookie cutters. Not sure if they will be wide enough They won't be wide enough, i run 7" cookies all around with GT flares and i run long wheel studs and 1" spacers to get them lined up with the flares nicely. That's with 225 wide tires ... (IMG:http://www.914world.com/bbs2/uploads_offsite/914world.com-4-11722-1528246391.0.jpeg) |
Chris914n6 |
Jul 2 2018, 01:04 PM
Jackstands are my life. Group: Members Posts: 3,307 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I picked up a set of chrome 15x6 and 15 x7 cookie cutters. Not sure if they will be wide enough They won't be wide enough, i run 7" cookies all around with GT flares and i run long wheel studs and 1" spacers to get them lined up with the flares nicely. That's with 225 wide tires ... You can get 16x8 Euromeister Fuchs for under $800. Good tire selection and the right look. The 1" spacer is built into the outer lip (IMG:style_emoticons/default/biggrin.gif) |
1970-1914 |
Jul 2 2018, 05:15 PM
I picked up a set of chrome 15x6 and 15 x7 cookie cutters. Not sure if they will be wide enough They won't be wide enough, i run 7" cookies all around with GT flares and i run long wheel studs and 1" spacers to get them lined up with the flares nicely. That's with 225 wide tires ... You can get 16x8 Euromeister Fuchs for under $800. Good tire selection and the right look. The 1" spacer is built into the outer lip (IMG:style_emoticons/default/biggrin.gif) Yes I was looking at those as well as the dr.911 repro alloys as well. He is only about 30 min from me which is pretty convenient. I was looking at either a15x8 + 15x9 set or the 16x8 + 16x9 set. These were apparently cast in Canada. https://fuchswheelcompany.ca/wheels Pierre |
Lo-Fi Version | Time is now: 2nd May 2024 - 01:29 AM |
