1970 914 project |
1970 914 project |
1970-1914 |
Jun 28 2018, 04:35 PM
Member Group: Members Posts: 97 Joined: 3-June 18 From: Vancouver Member No.: 22,186 Region Association: Canada |
I recently bought this partially restored 1970 914 shell off Craigslist for a pretty decent price. I have been looking for quite a while and there are only so many around in the Vancouver BC area and most are quite rusty if they are not $$$$$. The good news is most of the gross nasty metal work was already completed so in that regard I’m pretty far ahead for a project. Also came with quite a few decent parts - some I will use and some I will sell off to get the parts I actually need.
Not sure what I will do about engine choice.... would really like to do a 6 but based on cost I may end up doing a v8 or Subaru? Not sure but luckily I have a ton of other work to do on the rest of the car while I make up my mind. EDIT: V8 it is - Purchased most of a Renegade SBC kit (IMG:style_emoticons/default/smile.gif) The Formula Vee wheels were just way too skinny for the flares so they have been sold and I picked up a set of chrome 15x6 and 15 x7 cookie cutters. Not sure if they will be wide enough either to look correct but the deal was great and they will at least allow me to do the 5 bolt conversion. I have one side of the rear suspension all apart and the rear axle stub out - looks like it is the early style with the raised bosses in place for 5 lug. I will update with some pics once that is done and the trailing arm is back together. |
1970-1914 |
Dec 22 2018, 12:22 PM
Jim,
I thought about one of those 350’s - mostly because it is a quick easy solution. I then decided I should actually just find a decent 283 and deal with the hassle of redoing it to better fit the application. The short block I found in Seattle is a motor someone rebuilt at some point about 15 years ago and then just sat in a shop until all the assets were bought by the shop I am dealing with. I am heading down to pick it up after Christmas. The bores still look quite decent. I may be able to get away with disassembling it, quick clean up and re-assemble. Probably will end up changing the cam. |
jimkelly |
Dec 22 2018, 07:26 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
seems everyone says a 283 needs some modern small chamber heads like trick flow or world and a higher rpm cam.
http://www.competitionproducts.com/World-P...A/#.XB7j71xKjcs -- Jim, I thought about one of those 350’s - mostly because it is a quick easy solution. I then decided I should actually just find a decent 283 and deal with the hassle of redoing it to better fit the application. The short block I found in Seattle is a motor someone rebuilt at some point about 15 years ago and then just sat in a shop until all the assets were bought by the shop I am dealing with. I am heading down to pick it up after Christmas. The bores still look quite decent. I may be able to get away with disassembling it, quick clean up and re-assemble. Probably will end up changing the cam. |
Lo-Fi Version | Time is now: 2nd May 2024 - 04:01 AM |
