1970 914 project |
1970 914 project |
mgp4591 |
Dec 24 2018, 11:25 PM
914 Guru Group: Members Posts: 5,366 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
that Fitech efi setup looks sweet. i'm gonna run rams horns instead of shorty headers. according to this video, rams horns are fine to 5200 rpm. https://www.youtube.com/watch?v=qe9ke0rQlT8 They make ram horns that have a 2 1/2" outlet that's probably more flow than you'd need - they came with the high hp Corvette smallblocks. The small valve heads will get you to that 5200 rpm that the ram horns are good to without a problem. It sounds like a good combination all around. |
dan10101 |
Dec 25 2018, 01:37 AM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
I had a built 283 in a flat bottom boat. It had double hump heads, 10-1 compression, Duntov 30/30 cam, alum manifold and Holley 600. I suspect somewhere around 250-280hp. It moved it really good, but wouldn't idle for beans. Really tough to idle in a 5mph zone with 1000rpms and direct drive.
Chris914n6 |
Dec 25 2018, 10:00 PM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
FYI - Summit Racing has/had the FiTech on a pretty good sale for Christmas.
jimkelly |
Dec 26 2018, 08:27 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
turns out these guys offer a 283 crate engine.
https://www.fivestarengines.com/shop/chevy-...d-crate-engine/ Q- can you advise what compression cam pistons crank bore etc etc thanks jim A- "The compression ratio is 9.5:1 (good for pump gas). The pistons are a flat top design. The crank is a re-machined GM 283 crank with all new bearings and computer balanced. Every block is bored oversize and over 90% are .030 (first cut). The cam is a new Comp Cams high energy camshaft with .454 lift and 268 duration. Thank you for your interest. Chris. 623-939-0345" and Q- chris, so do they have powerpack heads? do you recommend 600 cfm 4 barrel carb? what horsepower and torque do you expect? thanks again, jim A- "We do offer the powerpack heads and install 1.94 intake and 1.50 exhaust valves. We do recommend a 600 cfm four barrel carb. The peak HP is 280 at 5000 rpm. Thanks again, Chris." AND A TIP FROM TOMREV TO ME SOME TIME AGO. "Stick with a mild cam, add the roller tip steel rockers, like I did, (around $90. a set), small carb, 500 to 600 cfm, headers like mine, but with 2 1/4 in. dia. exhaust pipes, HEI type dist. (mine is MSD, very nice, but $300.), maybe lighten the flywheel some. The 283 is a sweetheart, and with the smaller port aluminum heads ($1100.) from Trickflow really runs nice. Have fun with your build!" |
1970-1914 |
Dec 26 2018, 05:39 PM
Member Group: Members Posts: 97 Joined: 3-June 18 From: Vancouver Member No.: 22,186 Region Association: Canada |
I will disassemble the 283 shortblock I bought and see if I can determine what cam is in it and maybe replace with something more appropriate for higher rpm? From the pics I have it looks like a stock type piston. Possibly worthwhile to go with a slightly higher compression piston set while apart. Won’t really know till after it gets inspected.
jimkelly |
Dec 27 2018, 08:05 AM
i don't know if you ever plan on getting stuck in heavy traffic but i think a less wild engine is probably better for traffic.
especially if you'll be using stock transaxle and avoiding the use of 1st gear, as most do. 2nd gear in stop and go traffic sucks, as it doesnt work well for sub 10-15 mph speeds. probably would suck much more with a hotter cam and a bunch of compression? (IMG:style_emoticons/default/driving.gif) |
1970-1914 |
Dec 27 2018, 10:51 AM
So as the " low-buck v8 outlaw" thread title says suggests... this car is being built on a very low budget and will be a V8. If you have read much before this post most of what is going to happen with this build has been detailed.... so what does this low budget look like and how am I doing?
My goal is to be all built and painted with +/- 250hp for around $5500-$6000. This is only vaguely possible because the shell purchase was such a ridiculously good deal and I will be doing the remaining fab work, bodywork, paint and assembly myself. Quite honestly that is all the fun stuff for me anyway so looking forward to all that. Starting with a shell that was media blasted, all rust work done, chassis reinforcements welded in, epoxy primed and the complete underneath painted is a really really big head start in time and money. Costs so far: Shell and parts purchased for $1800 Parts sold off: Riviera wheels - $200 Stock 1.7 - $700 Misc efi parts - $200 Fender lip cut offs - $100 Stock steering wheel - $250 Total cost for shell: $350 (IMG:style_emoticons/default/biggrin.gif) Parts bought: Chrome cookie cutter rims - $500 then decided 6" wide was too skinny for the front and re-sold for $700. Bought second painted black set with tires for $250 so current wheels in total were $50. VB adapter, flywheel, pressure plate and disc - $130 Power pack heads - $50 Intake and HEI distributor - $30 283 Shortblock - $200 2 new 914rubber bumper tops black Friday deal - $470 Front and rear stock used valences - $100 Dash frame and gauges (missing when i bought the shell) - $150 Heater control - $50 Wiper motor and arms - $30 Momo wheel and Luisi early adapter - $150 5 bolt rear conversion (new discs, redrilled early hubs, new wheel bearings and 20mm spacers) $350 Front 5 bolt adapters - for now - $90 Flared FG rockers - $250 All in cost so far: $2094 So right now I have a mostly complete rust free V8 914 for $2100 which I think is a pretty great place to be at this point in the build. (IMG:style_emoticons/default/smilie_pokal.gif) Still to buy: Rad and cooling parts - $750 Windshield - $250 Misc v8 parts including headers and exhaust tubing/muffler - $750 Carb or efi set-up - $800 Misc interior parts (carpet, door panel recovering etc) - $500 Paint supplies - $500 Still needed: $3550 Target total cost: $5650 I'll be quite happy if that number jumps up another $1000 or so with the upgrading of the front suspension and brakes. I kind of see that as a phase 2 project after the car is up and running. If I go regular headers and carb instead of the 180* headers and efi it will shave about $1000 off the total. Also I think I can do better than budgeted on the cooling system if the right deals come up. I would have loved to have gone with a 911 6 motor of some sort but the price point even for a pos core motor and install parts would exceed my projected total budget easily and still would have needed rebuilding $$$$. |
mobymutt |
Dec 28 2018, 08:28 AM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
Nice!
I'm probably close to your build price, and I have a rusty shell, and some crappy 1.7 I just bought off somebody. (IMG:style_emoticons/default/biggrin.gif) |
1970-1914 |
Dec 28 2018, 10:03 AM
Haha nice.
Have you gone any deeper disassembling the motor or are you just going to put the heads back on and run it? Pierre Nice! I'm probably close to your build price, and I have a rusty shell, and some crappy 1.7 I just bought off somebody. (IMG:style_emoticons/default/biggrin.gif) |
jimkelly |
Dec 28 2018, 06:54 PM
i had bad drone at about 2000 rpm with dual exhaust and shitty mufflers. once i changed to magnaflow mufflers, the drone went away, but some say a crossover pipe is a good idea.
and that fitech looks sweeeeet but you can save $500+- in the short term by using a carb BUT i wonder what kind of fuel economy improvement FI will give on a 283 in the long run? lastly, the guy i got my 283 from advised me to add a zinc additive to my fuel and modern gas is unleaded and the 283 prefers leaded gas. something about wipping out the cam. https://www.youtube.com/watch?v=3Zj0RMPKquw Attached image(s) |
mobymutt |
Dec 28 2018, 09:07 PM
Just gonna put the heads back on and run it!
Haha nice. Have you gone any deeper disassembling the motor or are you just going to put the heads back on and run it? Pierre Nice! I'm probably close to your build price, and I have a rusty shell, and some crappy 1.7 I just bought off somebody. (IMG:style_emoticons/default/biggrin.gif) |
1970-1914 |
Jan 1 2019, 03:10 AM
I picked up a nice set of doors today from Rich at 914 Werke - I was just really looking for a passenger door but I decided to update both for the newer style window regulators and crash bars. I can see the value in that as I was t boned in my 1971 years ago and it destroyed the side of the whole car - windshield out and the targa top went flying into the ditch.
And here is the 283 short block (- the camshaft). |
Tdskip |
Jan 1 2019, 07:56 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
So as the " low-buck v8 outlaw" thread title says suggests... this car is being built on a very low budget and will be a V8. If you have read much before this post most of what is going to happen with this build has been detailed.... so what does this low budget look like and how am I doing? My goal is to be all built and painted with +/- 250hp for around $5500-$6000. This is only vaguely possible because the shell purchase was such a ridiculously good deal and I will be doing the remaining fab work, bodywork, paint and assembly myself. Quite honestly that is all the fun stuff for me anyway so looking forward to …all that. Starting with a shell that was media blasted, all rust work done, chassis reinforcements welded in, epoxy primed and the complete underneath painted is a really really big head start in time and money. Costs so far: Shell and parts purchased for $1800 Parts sold off: Riviera wheels - $200 Stock 1.7 - $700 Misc efi parts - $200 Fender lip cut offs - $100 Stock steering wheel - $250 Total cost for shell: $350 (IMG:style_emoticons/default/biggrin.gif) Parts bought: Chrome cookie cutter rims - $500 then decided 6" wide was too skinny for the front and re-sold for $700. Bought second painted black set with tires for $250 so current wheels in total were $50. VB adapter, flywheel, pressure plate and disc - $130 Power pack heads - $50 Intake and HEI distributor - $30 283 Shortblock - $200 2 new 914rubber bumper tops black Friday deal - $470 Front and rear stock used valences - $100 Dash frame and gauges (missing when i bought the shell) - $150 Heater control - $50 Wiper motor and arms - $30 Momo wheel and Luisi early adapter - $150 5 bolt rear conversion (new discs, redrilled early hubs, new wheel bearings and 20mm spacers) $350 Front 5 bolt adapters - for now - $90 Flared FG rockers - $250 All in cost so far: $2094 So right now I have a mostly complete rust free V8 914 for $2100 which I think is a pretty great place to be at this point in the build. (IMG:style_emoticons/default/smilie_pokal.gif) Still to buy: Rad and cooling parts - $750 Windshield - $250 Misc v8 parts including headers and exhaust tubing/muffler - $750 Carb or efi set-up - $800 Misc interior parts (carpet, door panel recovering etc) - $500 Paint supplies - $500 Still needed: $3550 Target total cost: $5650 I'll be quite happy if that number jumps up another $1000 or so with the upgrading of the front suspension and brakes. I kind of see that as a phase 2 project after the car is up and running. If I go regular headers and carb instead of the 180* headers and efi it will shave about $1000 off the total. Also I think I can do better than budgeted on the cooling system if the right deals come up. I would have loved to have gone with a 911 6 motor of some sort but the price point even for a pos core motor and install parts would exceed my projected total mibudget easily and still would have needed rebuilding $$$$. Wow, well done. Maybe I need to put you in charge of my budgets. Mild cam for street use is a VERY good idea. |
1970-1914 |
Jan 3 2019, 01:01 PM
Motor is apart - had a later 283 cast crank and not a forged one which was a bit of a disappointment.
The block is still the standard bore which is pretty good for a 55 yr old engine. Of course 7 of the 8 cylinders look like they would clean up well with just a honing.... the other cylinder may be too rusty (IMG:style_emoticons/default/sad.gif) |
1970-1914 |
Jan 13 2019, 11:01 PM
In other more exciting news I found a much better dash pad for the car (IMG:style_emoticons/default/piratenanner.gif)
1970-1914 |
Jan 14 2019, 04:46 PM
I will be taking the block in to get hot tanked and mag'd in the next couple of weeks. If decent it will be getting bored .030 over and new cam bearings pressed in.
The shop I am using has a great history of building winning circle track, race boat and drag motors here in Vancouver. It is going to be a fairly simple build with a factory forged 3" crank, scat rods and metric ring pistons. Cam wise I will likely leave that up to him - he is aware of what I want out of this motor. I will be turning my focus back to the body and paint side of this project for a while. |
1970-1914 |
Feb 4 2019, 11:40 PM
Thanks to Bob Burton and Jim Kelly for getting me some v8 mount measurements.
I was able to whip up this engine mount bar - just have to bring it in to work to mill the holes at each end for the bolt holes. There will be pipe sections going through the holes vertically to provide the right height spacing. |
1970-1914 |
Feb 5 2019, 08:58 PM
djway |
Feb 5 2019, 09:37 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Could you share the measurements?
1970-1914 |
Feb 6 2019, 12:16 PM
Lo-Fi Version | Time is now: 26th April 2024 - 12:06 PM |
