Reattaching Mirror to Windshield, What are you using? |
KELTY360 |
Jul 7 2018, 06:59 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
I've got a '75 914 with an inside mirror that has detached from the windshield I've looked at the two part adhesives but they don't work for an entire mirror assembly.
What have you used to reattach the whole mirror assembly? |
iankarr |
Jul 8 2018, 03:17 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Agree on the OEM adhesive pad. Clean surfaces well with alcohol. The mirror mounts lower than you'd think it does. To line it up, flip the sun visors down and center the mirror in the cutotus. That should get you close. Then use a wax pencil on the outside to mark the horiz and vertical centers.
If you need to remove an existing adhesive pad, try acetone in a syringe and a hair dryer. Don't use a heat gun, as you could crack the glass. Good luck! |
burton73 |
Jul 8 2018, 03:22 PM
burton73 Group: Members Posts: 3,520 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Agree on the OEM adhesive pad. Clean surfaces well with alcohol. The mirror mounts lower than you'd think it does. To line it up, flip the sun visors down and center the mirror in the cutotus. That should get you close. Then use a wax pencil on the outside to mark the horiz and vertical centers. If you need to remove an existing adhesive pad, try acetone in a syringe and a hair dryer. Don't use a heat gun, as you could crack the glass. Good luck! This is right by me but I used blue masking tape on the windshield to mark the outside of the target. Bob B |
Lo-Fi Version | Time is now: 14th May 2024 - 05:58 AM |
