Corroded front 911/914-6 hub, this could be scary. |
Mueller |
Jul 9 2018, 09:29 AM
Please inspect your front hubs!
While changing out the rotors and pads on Sandy's original /6, we found the passenger side front aluminium hub badly corroded. Best guess would be from dissimilar metal contact. He will be in the market for one good hub , if you have one for sale please PM me. Drivers side is in perfect condition. |
Jul 9 2018, 09:49 AM
914-6 GT in waiting Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mike -I’m pretty sure I have a good one that will match that one - with the correct size dust cap. It was the match to the corroded hub I sent you. Maybe battery acid took out one side.
The hub I sent you looked pretty but I could flake off pieces with a screwdriver. This hub looks to have the same issue. Send me a pic of the hub to mark@markepstein.net and I’ll make sure it’s a match. If Sandy wants to buy it and wants both hubs vapor blasted, you can always send me the good hub and I can send both of them back once done. I can turn it around in a day. Attached image(s) |
injunmort |
Jul 9 2018, 10:26 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
great example of why you paint alloy.
Jul 9 2018, 10:42 AM
great example of why you paint alloy. Well...the origionals weren’t painted and the ones I vaporblast aren’t either. But if you are going to paint, it has to be some sort of epoxy or powdercoat that won’t react to brake fluid. I don’t know why one hub went bad and the other is fine but I don’t think most of our cars will get used like they used to. |
Lo-Fi Version | Time is now: 17th June 2024 - 08:12 AM |
