| Mikey914 |
Jul 12 2018, 03:37 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,786 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
| campbellcj |
Jul 13 2018, 10:52 AM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,726 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
Mine broke-off too and I've been unable to get the remnant out of the car. Not a great design even as a forged part IMO, if you're actually gonna use it (i.e., track car). Left handed drill bit works well. Thanks, I will try that! I have tried an easy-out type of thing to no avail. Obviously the forged steel is extremely hard, and it's been screwed in there really tight for several years now. Possibly in there for good at this point. |
| mb911 |
Jul 13 2018, 11:29 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,856 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Is it flush with the end? You could weld a nut on the broken fastener then remove easily.
| Mikey914 |
Jul 13 2018, 12:16 PM
Soak it with penetrating oil and let sit for an hour or so to let it weep into the areas it can. Use a smaller bit to make a pilot hole and go to town with the largest bit you feel comfortable with (as not to damage the threads).
Mark |
Lo-Fi Version | Time is now: 24th November 2026 - 03:08 PM |
