914 fuel line options?, what to replace the original lines with |
VintageExcellence |
Jul 10 2018, 02:46 PM
Member Group: Members Posts: 52 Joined: 27-August 04 From: San Diego, CA Member No.: 2,636 |
What are you guys doing on fuel lines. I am restoring a early 914-6 with the 2 different size plastic fuel lines through the chassis. I pulled the original lines out, one broke from being brittle and the reason I wanted to change them. What options are out there?
I see stainless steel line replacements. Looks like Tangerine has a set for sale. Anything else out there? |
porschetub |
Jul 10 2018, 05:17 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I used late VW plastic FI line and ferals then truck metal brake pipe @ the front,EFI hose clamps only,my original plastic hose was as new but heeded the warning from this forum...feel happier I did the replacement.
Mark Henry |
Jul 10 2018, 10:06 PM
I used late VW plastic FI line and ferals then truck metal brake pipe @ the front,EFI hose clamps only,my original plastic hose was as new but heeded the warning from this forum...feel happier I did the replacement. If the plastic lines are good I wouldn't worry about it. If damaged, you welded in new floors (welding heat), or you are running high pressure for a front FI pump, then I'd use the SS lines. With a stock location pump these lines are low pressure, only the pump to regulator FI loop is high pressure. The truck brake pipe is OK but it should have a rolled barb, especially for high pressure. FI clamps should be the only type used and SAE 30R9 rated FI fuel hose. I used to say SAE 30R7 hose was OK for all the low pressure sections and carbs, but after some research on hose quality I will now only use SAE 30R9 rated FI fuel hose on all the fuel lines. |
Lo-Fi Version | Time is now: 8th May 2024 - 02:12 PM |
