| phatnine11 |
Jul 11 2018, 05:30 PM
Member ![]() ![]() Group: Members Posts: 286 Joined: 22-March 05 From: Rancho Cucamonga, CA Member No.: 3,798 |
Ok, the question is about SS vs mild steel. Most folks would probably chose SS due to the fact that RUST is a dirty and nasty word around 914 people. The fuel lines will reside in a rusty location unless the center console has been rebuilt. Beg, borrow or buy a bore scope and have a look.
Phatnine11 |
| jcd914 |
Jul 11 2018, 05:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
This question may be heresy, but are SS lines necessary? Would regular steel lines provide a pretty long service life? There is a how-to on the bird for making fuel lines from steel brake line. (IMG:style_emoticons/default/hide.gif) A more basic question is: is having and driving a 914 necessary? If you are going to go to the trouble of updating your fuel lines (which I think is a really good idea to avoid that burnt-up car thing), the incremental cost difference between SS and mild steel lines seems trivial. Especially when reasonably priced SS lines are available sized and bent to the exact correct spec. Please add me to the list of satisfied Tangerine customers. Chris is the best. Okay, I'm going to poke the bear again (IMG:style_emoticons/default/poke.gif) The problem is that when you are doing a bare metal full restoration on a budget, these trivial incremental up-charges add up to real $ in a hurry. So I try to figure out which provide real bang for buck versus just paying extra to have a knob that goes to 11. That's why when I bought brake lines, I opted for PMB's economy mild steel kit because even those lines in a well-maintained system will outlive me and the savings was substantial. I'm not questioning the quality of the pre-bent kit options, or the wisdom of paying what is necessary for a safe fuel system. I'm just wondering what the safety and longevity of SS fuel lines vs mild steel would be. (IMG:style_emoticons/default/bye1.gif) Yes you can use mild steel tubing to make your own fuel lines. Buy zinc coated/plated tubing and rust won't be a problem anytime soon. You could also buy stainless steel tubing and make your own lines. Either way you have to figure out how to get a beed on each end so your fuel hose doesn't slide off and bend them to shape. Probably the same amount of work and similar cost. My car came with SS lines (Chris's) so I didn't have to chose. Jim |
| worn |
Jul 11 2018, 05:59 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,652 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I bought ss tubing from JEGS and silver soldered AN fittings to the ends. That was because I like to learn by doing everything myself. Else, supporting those who support the marque, 914 specifically, is the way to go.
| Mark Henry |
Jul 11 2018, 08:37 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I did my '67 bug in 3/8" brake line, I had to do two lines because my engine is EFI. It's my summer DD and they still look like new.
Make sure you use proper gromets where lines go through steel panels. |
Lo-Fi Version | Time is now: 26th September 2026 - 04:16 AM |
