my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
jmitro |
Jul 12 2018, 11:33 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
definitely need to wet sand with finer and finer grits; don't wet sand with anything finer than 1000 unless you want to just paint the panel again. or be sanding from now until 2020. Trust me, it takes a lot of sanding to get the panel flawless;
no reason to use polish until you've got to at least 1500 if not 2000 grit. change the sandpaper frequently; it gets loaded quickly |
Lo-Fi Version | Time is now: 17th May 2024 - 01:02 AM |
