my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
914 RZ-1 |
Jul 16 2018, 02:44 PM
I just to-read this and noticed that some people told me to go 30psi at the gun. The engine lid turned out really well because I think I had the gun pressure turned up. I can't remember, though. (IMG:style_emoticons/default/headbang.gif)
I have the hoods to repaint so I will try increasing the pressure for one of those and see how it turns out. Stay tuned! In the meantime I have sanded the car body down with 400 grit and "prep and wash". I sanded the "mountains" down a bit, but not all the way. I want to leave me some paint for sanding later. I figure I'll fill in the "valleys" (and make the "mountains" taller), but that will give me some material to sand off. Thoughts on this? I'm hoping the paint will go on smoother and I will only have to sand with 1000 grit and up. |
Lo-Fi Version | Time is now: 22nd May 2024 - 05:49 AM |
