my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
Literati914 |
Jul 16 2018, 04:00 PM
Senior Member Group: Members Posts: 1,461 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
As far as the paint mix, only do what the tech sheets call for, for your particular paint on the air psi and mix ratios. Well meaning people will tell you what works for them but they're probably using a different brand etc, so it's not necessarily pertinent info.
I recently painted my '71 Volvo 1800E with single stage.. and started wet sanding with 1000, didn't work so I (somewhat fearfully) dropped to 800grit as my starting paper - and all turned out just fine. Just antidotal but if there's enough paint laid down, shouldn't be a problem. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:05 AM |
