my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
Cairo94507 |
Jul 12 2018, 07:38 AM
Michael Group: Members Posts: 9,722 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
That's a bit of orange peel for sure. I would tape all the edges on one panel (don't want to sand or burn through) and wet sand it some more to see if you can get 90% of that flattened out and then try polishing. Just take your time. Good luck. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 1st May 2024 - 05:31 PM |
