my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
Andyrew |
Jul 12 2018, 11:05 AM
Single stage? What paint are you using?
Go 30% more reducer than you were using. Change your air pressure at gun regulator to 30psi, Adjust your spray to 6-8" of surface. Spray test piece with another 3 coats after 400grit wetsand and clean up with wax/grease remover. Show us what you've got. Be careful with runs. If you plan to wetsand always do 4+ coats. or 2+ coats after full coverage. I did 7 on mine. it took 3 to get full coverage. I wet sanded out 1-2 coats and have 5 coats on the car and can wetsand the car again 2 times to eliminate imperfections down the line. |
Lo-Fi Version | Time is now: 2nd May 2024 - 06:35 AM |
